Daven54
11
Bmw 335i
Hey guys i was just wondering if anyone has notice if they have gotten a clunk when putting the car in gear and when changing gears, i also have a bms diff brace
1,620
I noticed a clunk when going from P to D or R and starting to roll. I suspected (correctly) that the origin of the clunk was in my brakes and it disappeared after I tightened up and lubricated my calipers when I installed new rotors and pads.
Panzerfaust
637
439
Chicago
E92 335i
I believe certain kinds of clunks can also be caused by very worn bushings as well, especially if going from driving one direction to another (D>R, N>D, R>D etc) due to the diff shifting slightly when the load changes.
1,497
Normal in a manual car for a LSD to clunk when going from neutral to first or from R to first or vice versa.
Dunno about auto.
I get a clunk, but it sounds like my brakes and I'm pretty sure it is. I have AKG black diff mounts and an MFactory lsd. I have F30 brembo kit in back and its not 100% so I can't imagine it is anything else.
scrllock
267
152
2011 335xi
Did you get a full pumpkin or install a new diff into your carrier? If the latter, did you have your shim/bearing done properly?
1,620
When was the last time you worked on your brakes? I had a loose caliper which caused my clunk.
1,620
My brakes had been untouched for about four years when my clunk developed. You’re probably still good in this regard.
Daven54
11
Bmw 335i
i got a performance shop to install the lid into the carrier and i installed the pumpkin into my car but i replaced all the bearings and provided all new shims, i was wondering if its the differential brace that is causing me to notice the clunk. Im going to remove it and see if i can still hear or feel the clunk. Also i don't hear or feel any whine or gear noise when accelerating or decelerating
