Dusty Waterfall
Dusty,
What is the small side ID of that transitional adapter?
Thanks,
Rob
The same as the ID of the mating surface at the turbo. This was done to accommodate high flow offerings such as the PS2's.
Dusty,
Thanks,
Rob
This looks like it goes onto the end of the compressor outlet onto the existing v-band feature. If so, it is after the "step" inside the compressor housing that Rob is talking about, isn't it?
Why would that be a better test when the whole point of an upgrade is an upgrade? When you buy an air intake that says 27 percent better flow you don't complain they didn't cut holes in the lid of stock box during comparison. He tested stock unmodified vs his with no games or trickery, he actually did the most straightforward thing he could have done.
So if his outlets were on stock turbo your saying would flow worse than stock. Then my question is if on gc turbos they would out flow stock?
