Hey everyone,
this is my first post on here so I apologize if I am posting in the wrong section or beating a dead horse.
I am currently in the process of rebuilding the N54 out of my 2008 335i. The engine spun a rod bearing, and the cylinder bores were too worn to be reused with standard-sized pistons. The rod journal on the crank for the spun cylinder was also pretty marred up. Because of this, I decided to purchase a good used block with cylinder bores in spec, and a nearly perfect 6 bolt crankshaft so that I can use the 335is clutch and flywheel. My plan is to reuse 5 of the stock piston-rod assemblies and purchase an OEM connecting rod used on eBay. I intend on using standard King main and rod bearings, however I have not decided between ARP and OEM main studs, head studs, and rod bolts. Aside from the plans I have mentioned, I have no idea what I should change while I have the engine apart. The water pump looks to have been upgraded to an all aluminum unit, however I do not know the condition of the HPFP or injectors. Aside from basic maintenance items, do you guys have any recommendations for upgrades while I'm in there? Also, I would appreciate any tips and tricks for building an N54, as this is my first time dealing with an overhead cam engine (I'm used to pushrod V8s).
Thanks!
Jack
Thanks!
Jack
