Hi folks
I have f10 n63 keep appearing this faults and power for car is perfect no limp mode , I was checked vacuum leak , and replaced the wasegate valve solenoid for bank 1 and 2 but issue still
Since this is on JB4, I assume you can record a log. I would start there. If not, display the gauges and set one for Boost Target and one for Boost (Boost Actual) and see how much you are underboosting. My guess is boost leak
What year is car and what maintenance that could be a lot of things but common things are the vanos solenoids and like already said first thing to check before throwing money is leak but I would assume you would know if was leaking . How much boost are you running ?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
