Drivetrain malfunction
Ez096
10
Hi folks
I have f10 n63 keep appearing this faults and power for car is perfect no limp mode , I was checked vacuum leak , and replaced the wasegate valve solenoid for bank 1 and 2 but issue still
Any idea
DaddyBoost
55
-4
Since this is on JB4, I assume you can record a log. I would start there. If not, display the gauges and set one for Boost Target and one for Boost (Boost Actual) and see how much you are underboosting. My guess is boost leak
  • Dislike
Reactions: RuskiRacer
978
Have you checked the couplers going from the turbos to the intercoolers. I’ve heard their notorious for cracking and go bad.
What year is car and what maintenance that could be a lot of things but common things are the vanos solenoids and like already said first thing to check before throwing money is leak but I would assume you would know if was leaking . How much boost are you running ?
